B end play adjustment
Hig 5060
03-06-2007 05:58:42
Is the correct way to adjust end play on the crankshaft is to engage the clutch and then tighten the flywheel down? I have a book but I don't think it says to hold the clutch forward someone told me this I think sometime along the way. Thanks guys. .002 to .004 I think.
Hig 5060
03-06-2007 16:03:27
 Re: B end play adjustment in reply to Hig 5060, 03-06-2007 05:58:42
Where do you measure the .005 to .010? Do you stick a gage between the flywheel and the main housing or just kind of guess at it.Thanks!
Mike M
03-07-2007 04:37:07
 Re: B end play adjustment in reply to Hig 5060, 03-06-2007 16:03:27
If you have a dial indicator it is real easy. you can just stick it on anywhere you can get a reading between the main case and the fylwheel. If you don't have one yet you may be able to use something like a block and a feeler gauge in between the fylwheel and case. Or at the very worst guess. Just make sure you have SOME free play as too tight will bind it up and cause major problems. Error to the side of too loose.
Mike M
03-06-2007 06:52:45
.005"-.010" is the endplay setting. The clutch has no effect on the settings but pulling back and forth on the handle can aid you in seeing how much play is there if you can't grab ahold of the fywheel due to a cover.
