AS JDNPC stated, start with the basics. You are going to need the MT series manual for the MT TOM unit [the manual for the M series is different than the MT]. There are many small parts & removal techniques that will keep you from damaging the check-valves by reading the manuals. after you have her warmed-up, find the pressure line that leaves the pump and enters the valve-housing. Start to loosen the line at the v-housing and if you start to get some real pressure and squirting, then the pump is working. At this point, [if the oil & fluid levels are good/correct to spec], you will need to remove the TOM and take it apart. YOu might as well give it a good thorough going over. DO you know the last time it was working properly?? If not or it has not worked for yrs, and subject to the condensation, there is a good chance there is some H20 in there and it has rusted-up some of the valves/bores. When i pulled mine, i had Mississippi mud come out of it, and i do not live anywhere Miss. Post back and let us know, Regards, tstex
