51B Resto--Darn that hurt!
Greg F
01-03-2000 17:19:25
I now have it tore down to the maincase. So I think I'll give the flywheel a spin and see if oil pumps. Halfway through the first revolution I ran my right middle finger tip through the flywheel and starter housing. Lucky - resized it just a little. Later with ice on my finger and taking liquid JD pain killer, I start kicking the flywheel around for several revolutions (no more hand turning for a while). Oil starts flowing constantly from the fitting that goes to the guage. Oil is also pumping and slinging from the rod journals on the crank. I then notice that the oil galleys for the block and the govenor pulse oil - not a constant flow. Is this pulsing flow normal? I would expext it to be from the rod journals but to the block and govenor? Thanks Greg.
Craig
01-07-2000 19:45:19
 Re: 51B Resto--Darn that hurt! in reply to Greg F, 01-03-2000 17:19:25
Ouch!!!!!
Anyway, I had the oil pump out of my 50 B a couple years ago to clean the 2 inches of gunk out of the crankcase and I disassembled the complete pump and found this hole cross drilled in the main pump driveshaft. After studying the pump body passages and plumbing I determined that it is metering the oil flow to something somewhere.
OILCANHARRY
01-04-2000 12:47:45
The line to the tappets should pulse. There is a flat on the pump shaft that opens a passageway for roughly a quarter of a turn of the shaft allowing full pressure oil to pass through the block and head to the tappet oiler tube. This passage is closed for the rest of the rotation of the shaft thereby limiting oil delivery to the tappets.
