Dave: I waited until maybe someone with a bit more expert knowledge level would answer you, but it's been a ahwile and I didn't want you to think you were unloved. :) As to the polarity, that's an old engineering saw that some EE's thought a lot of and others did not. As long as the generator charges (if it has an alternator on it, that is most likely why it has been "converted....alternators are most predominately negative ground units), then everything should be fine. One last thing to check is that the same sign of the battry ground is the same sign that the wire going from the coil to the distributore is. That is, if the system is a positive ground, then you should have the + terminal of the coil going to the distributor, and if it is a negative ground system, then the - side terminal goes to the distributor. If you have a magneto, then you have no worries as the mag makes its own power. One last thing is to determine that the ammeter has had its leads reversed when the polarity was changed so that it indicates charging when the generator is indeed charging. The easiest way to check this is to turn the lights on, engine off, and the ammeter should show discharge. If it moves to charge once the engine is running and the generator is spinning, then you have a everything set correct. Frank
