? about buying JD B
smdv806
03-04-2007 19:30:54
I have an opportunity to buy a 1950 John Deere B? The price is good. What should I watch for on this model? What things such as fenders increase the value? What tends to go bad on them?
MDM
03-05-2007 19:16:24
 Re: ? about buying JD B in reply to smdv806, 03-04-2007 19:30:54
If you are looking for a B to go on tractor rides, you might want to consider the 2 stick transmission, they are a bit faster, other than that a 1950 B is a good all around tractor....I enjoy mine and use it a lot
Ravgardner
03-05-2007 05:06:01
Great tractor. I'd love to have one of the last B's off the line in the early 50's. I'd recommend checking for a cracked frame. Usually on the pully side a crack can form between the frame openings for the spark plug etc. It can be welded which usually fixes it for good.
Farmboy169
03-04-2007 19:52:20
The power-trol runs of the PTO shaft internally
Farmboy169
03-04-2007 19:41:15
A buddy of mine has a B, I'm not sure the year but it is styled. He has had good luck with it. The only thing that is wrong with his is something in the power-trol is a little wack-o, other then that it has been a good dependable tractor. Enjoy!
smdv806
03-04-2007 19:42:43
 Re: ? about buying JD B in reply to Farmboy169, 03-04-2007 19:41:15
What do the hydraulics run off of? Pto?
Scott's B haven
03-05-2007 15:11:40
 Re: ? about buying JD B in reply to smdv806, 03-04-2007 19:42:43
Ya the hydraulics are not live.So you have to use your head when mowing.
B-maniac
03-05-2007 16:30:39
 Re: ? about buying JD B in reply to Scott's B haven, 03-05-2007 15:11:40
I also chose a '50 "B" to keep for myself. Most came with power trol , roll-o-matic and clam shell fenders. There are a lot of good used fenders around if it don't come with them. If you can put it under heavy load somehow , check to see if it jumps out of second or third gear and also how elongated the draw-bar pin hole is. These are indicators of a lot of plowing or heavy tillage use and probably a hard life. Tin tends to get beat up sometimes too. GOOD USED replacement tin is getting hard to find. Good straight tin can save you hundreds if you are restoring . There are lots of these around so don't settle for a "money pit". You can get one that needs nothing and with nice paint and tires for $3500-$4000 so you can't go much over$1500-$2000 for one with "needs". Good luck , they are a great little "popper".
Gr8Bald1
03-05-2007 23:48:09
 Re: ? about buying JD B in reply to B-maniac, 03-05-2007 16:30:39
That's a great tip about the elongated hole in the drawbar but also a great testimony on how strong these little tractors are! The hole on my 51 B is way elongated! Having done a COMPLETE refurb I can tell you these machines were WAY overbuilt. I replaced plenty of bearings and bushings while mine was going back together and also had to install oversize pistons because my cylinders had become egg-shaped but I can't think of any one area that could be called a common problem. The reply about the slow speed for a tractor ride is dead-on. I can only make 11.5 MPH levelled off in 6th gear.
