GM Battery Location
Mixman
03-04-2007 16:06:32
We are in the midst of a GM #16602, a very late 1945 that has a home made seat on it. I can't find any literature about the battery location. I was told it goes in front of the valve cover. Anyone help?
Wimpfarm
03-04-2007 19:39:11
 Re: GM Battery Location in reply to Mixman, 03-04-2007 16:06:32
third party image
The batt is located in front of the valve cover as in this pic.
Click these links for more pic's
Link
Link
Link
Link
Terry..... .
G/MAN
03-04-2007 16:20:39
Yes, the batteries on "GM"s were mounted in front of the engine between the frame rails. The same location was used for a while on the regular "G"s that succeeded the "GM" after the model designation was changed back, until the battery-box seat was adopted, at which point electric starting and lighting became standard equipment, if I remember correctly. A "GM"-specific parts manual or the later dealer-style parts manual that covers all of "G" production should show the parts you need. Keep in mind that electric starting and lighting were optional on the "GM", so you'll need to look under "starting and lighting" in order to find the components in the index. If you don't have the parts book(s), your local JD dealer can pull the proper pages up on their PM Pro parts system and print them off for you, or photocopy pages out of the paper manual. The manuals themselves are available from JD Service Publications, or can probably be found on ebay or at swap meets. I have a "GM" parts manual, but am not really too interested in parting with it.
F-I-T
03-04-2007 16:16:04
Pages 110 through 114 of the Parts Catalog (PC369) shows the battery base and cover that was used in the serial range of your tractor, which mounted the battery forward. I don't have any photo of the exact location. The cable picture on 114 shows the cable running forward from the starter motor to the front nounted battery.
Fra nk
