DLTX 86 on JD 50
Buck D.
03-04-2007 14:00:09
I am working on a gasoline 50 that just had the carb rebuilt.The tractor idles perfectly,but at about half throttle,it starts to surge until you pull the choke out about half way,then it will run up to full throttle ok.Fuel flow to the carb is fine.I don't know how to adjust for this.Anything else that I could be overlooking?
03-04-2007 18:05:42
 Re: DLTX 86 on JD 50 in reply to Buck D., 03-04-2007 14:00:09
My 50 surged when I 1st got it. The idle pasages were pluged .I could clean it up put in a new carb kit but til I was told to clean those pasages it would surge.Put in cleaning dtlx carb at the top of the page and you will find talk about it.Also don`t know if it matters but my carb is a dtlx 75 .Maybe the 86 was for all fuel but mybe it don`t matter.web site www.robertscarbrepair.com may help.Hope this can help some.Good luck
55 50
03-04-2007 19:01:44
 Re: DLTX 86 on JD 50 in reply to [email protected], 03-04-2007 18:05:42
Both numbers are correct gasoline carbs depending on your serial number. DLTX-75 is listed for serial 1 through 22299. DLTX-86 serial 22300 and higher. This is listed in Service Manual SM-2024 on carburetors.
