Hard statr 420
Tommy W. Thomas
03-04-2007 13:55:03
My 1957 420 will start when it is cold most of the time. When it runs a while and gets hot it will not crank again untill it gets cool.
any one with any suggesations as to what the problem is would be appricated.
ram ranch
03-04-2007 15:38:29
 Re: Hard statr 420 in reply to Tommy W. Thomas, 03-04-2007 13:55:03
Make sure all the battery cables are good, and the stater needs to be good, 99% of the time the starter is in need of a rebuild or the cables are bad on all the Dubuque that I have worked on.
jCarroll
03-06-2007 13:55:36
 Re: Hard statr 420 in reply to ram ranch, 03-04-2007 15:38:29
Often an original 6 volt cable has been replaced with a cheap auto parts 12 volt cable, which is considerable smaller. I think an O or OO gage wire is the original size.
Same thing with the ground strap - often replaced with a 12 v cable. Make sure the ground connection is "good".
Agri Services has replacement cables which are primo.
