magnet on front pump?????????
BSer
03-04-2007 11:04:31
I just bought a JD 510B with hydraulic problems. What is the part on the front hydraulic pump that is circular and has 2 wires? It is around a shaft protuding from the top of the hydraulic pump? The pump was tested and is fine;but sill no hydraulics. Could this be a magnet to operate a valve? Any help appreciated..... ...Anyone with manuals for this machine????? ????
G/MAN
03-04-2007 11:29:00
 Re: magnet on front pump????????? in reply to BSer, 03-04-2007 11:04:31
Sounds to me like an electric automatic de-stroking valve, used to allow the pump to turn more freely and place less load on the starter motor when the machine is started cold. And yes, it could be causing the problem if it's staying "on" after the engine is started.
