720 Diesel Ring Gap
Zeke Miller
03-03-2007 21:55:50
I got a call tonight from a friend putting together his 720 diesel with new 90 over pistons. He asked if my service book mentions what the ring gap should be because he is measuring 0.005" and thinks it is to tight. My manual says nothing about the ring gap except that the rings are preset and need no further adjustments. He said they are hasting rings but did not see any ring gap specs on the package.
Since he will not be able to get anybody on the phone until monday, does anyone know what the ring gap should be?
F-I-T
03-03-2007 22:11:46
 Re: 720 Diesel Ring Gap in reply to Zeke Miller, 03-03-2007 21:55:50
When I rebored my 70D and installed new .045" over pistons and rings, I checked many resources, and finally settled on the box flap number from the Hastings (the rings I used). I found their recommendation to be .004"/1" of bore. That would be right at .025" for .045" over, so at ,090", what around .026" or a bit?
For sure .005" sounds like you might break rings as they warm up if set at .005" total. I know some set them at .003"/1" if and only if you intend to break it in s-l-o-w-l-y, maybe on a dyno, and don't plan to work it hard until it has had a significant amount of time to settle in, but .004"/1" seemed a comfortable number for me, and it has run strong with no blow by ever since.
Frank
Zeke Miller
03-04-2007 07:08:26
 Re: 720 Diesel Ring Gap in reply to F-I-T, 03-03-2007 22:11:46
Thanks for the info Frank. I made some phone calls this morning and they agree with the 0.004" End Gap/1" Bore formula.
