4020 rockshaft piston bore pic / hi-res = LARGE
Jason Z in MO
03-03-2007 21:08:11
third party image
I finally got my camera working again. Here is the picture of the rockshaft cylinder bore I had written about a week or two ago. The problem I'm trying to solve is the rockshaft settling withing a minute or two as soon as the tractor is shutdown. I did find the thermal relief valve tip was very damaged. I lapped a new valve to the seat. I'm not sure what to do about the cylinder yet.
I left the pic hi-res so you could see as much detail as possible. Jim, msb, Mike or anyone, do you think this is acceptable?
Thanks,
Jason
Nylon
03-04-2007 15:53:51
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Jason Z in MO, 03-03-2007 21:08:11
Jason thanks for posting pics on your rebuilding. I am not as good as you guys in machine shop expertise but have no problem doing assembly work. Getting visuals on internals help a bunch. The shop manuals on the 4020s are not too good. Always seem to have a picture of the exception model component. ie 5020 with highcrp sprayer attachment in reverse mode. Rather than what it looks like on the 4020.
Jason Z in MO
03-04-2007 16:52:46
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Nylon, 03-04-2007 15:53:51
Nylon,
If you want to see something specific let me know. It's all apart now!
Nylon
03-04-2007 23:23:36
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Jason Z in MO, 03-04-2007 16:52:46
Jason,
Did you notice your hydraulic pump kicking on when holding up anything heavy on rockshaft? Wondering if those sleeve grooves had enough flow to make it kick on...guessing it did. Or is the rockshaft not tied into the front pump? I know lifting the snowblower on mine the pump kicks in. And when I run the loader it will kick on. I never hear or notice pump run when steering.....wondering if an internal hydro leak would make a pump run.....Always wondering if I have any internal leaks but pump only runs when something used. Also cant remember..is yours a power shift or synchro?
John
Jason Z in MO
03-05-2007 08:02:35
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Nylon, 03-04-2007 23:23:36
John,
My 4020 is a syncro range. Actually, I don't notice when the hydraulic system calls for fluid. I don't hear any changes to the pump or engine when the pump is under load. I had a loader on this tractor a couple years ago but I sold it. I didn't need it anymore. I use a batwing mower and the loader or mower never seemed to make much difference.
The front pump or main pump runs all hydraulic functions. The transmission pump is only used to lubricate the transmission itself and drive oil through the filter to the suction side of the main pump. This is for the syncro range, I not sure about the powershift transmission.
With the engine running, the rockshaft would hold it's load without any issues. I never detected it hunting etc. I'm sure oil was squirting past the piston o-ring but I couldn't tell.
Jason
msb
03-04-2007 11:42:16
Wow Jason, that is the worst scoring I have ever seen,but I bet you will be surprized about the cost of a bore and sleeve job. I would check both options out before I bought a complete housing.If you decide on honing and replacing the o-ring,you will probably be able to use the rockshaft if you keep in L&D all the timne.
G/MAN
03-04-2007 12:48:49
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to msb, 03-04-2007 11:42:16
I agree - I've never seen one anywhere near that bad. Makes you wonder just what the heck happened. Hard to say what it would cost to bore and sleeve. Could vary widely according to who's doing the work, I guess. For a working tractor with big loads on the hitch a lot, I'd recommend fixing it right. For a lightly used tractor with small hitch implements, I'd at least take the chance with new seals. And it may sound pretty "shade-tree" coming from a JD service tech, but I might even try a little JB Weld in those really deep grooves and then carefully smooth them up with emery cloth or a flapper wheel on a die grinder before running a hone through the cylinder. Sounds kind of cheesy, but I've fixed liner o-ring ramps and bores in Caterpillar 3306 blocks that way.
Mike M
03-04-2007 15:32:58
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to G/MAN, 03-04-2007 12:48:49
I can maybe ? see JB holding up in an oring area where after assembly it is not subject to movement. But I would really doubt it will stay put inside once that piston slids around in there and the high pressure works on it. I would really worry about it flakeing back out and going on and plugging up something else in the system.
G/MAN
03-04-2007 16:29:09
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Mike M, 03-04-2007 15:32:58
There's always that chance, but if honing and resealing don't work, you're going to be pulling the entire housing off for repair or replacement anyway, and I doubt that those particles of JB Weld are going to be any more damaging or any more likely to circlate through the system than the normal amount of metal that's worn off of various components and finds its way through the sump screen and to the tranny pump. You're not going to be putting pounds of the stuff in there.
Jason Z in MO
03-04-2007 17:18:44
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to G/MAN, 03-04-2007 16:29:09
I wish I knew what happened and how it got so bad. I suspect the piston was replaced at some point because it looks great. Maybe piston is much harder than the casting so it wasn't damaged? Actually the oring and packing on the piston isn't cut or scared, that I can see. The packing does have a funny looking step where the plastic rings overlap. I will try to take a pic tonight.
I did look today and I can see honing marks in the cylinder. Perhaps it was honed when the piston was replaced?
I had thought about JB weld too. Run the hone through after knocking off the high spots. That might test the JB Weld on how well it will hold up to that torture. If it's still in there after that it should be a very small sliver in the grooves. I guess there is a chance pieces of it could clog a valve. It's a small fraction of what the system has pumped in the past!!!
The heaviest thing I put on the 3-point is a Reese hay mower. Otherwise the heaviest draft load would be a 4 bottom plow or a small chisel plow.
I guess this just tells you how durable the 4020 hydraulic system is!
Tomorrow, I'm going to check with a hydraulic shop about sleeving and call around for pricing on a used rockshaft housing. I didn't want to remove the valve housing and rockshaft (shaft) but it sounds like I need to no matter what direction I go.
I assume I should strip it down to even hone so I can clean out the grit?
I gotta thank all you guys. I literally have a whole team of trained JD mechanics assisting me!
Thank you!
Jason
Jason Z in MO
03-04-2007 21:04:23
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Jason Z in MO, 03-04-2007 17:18:44
third party image
Here is the piston. I was wrong there are some very very small scratches. You can't feel them but under the right light you can see them.
Can you guys help me understand how to use the hone? I have one that I picked up over the years but have never used it. You can see part of it in the picture. I don't know what grit the stones are or if that matters. I know you chuck it up in a drill and move it back and forth... Do I need to know much more?
G/MAN - I should add...
03-04-2007 11:38:50
Getting those pistons back in with new seals on them can be a bit of a challenge, at least on the larger tractors I have done it frequently on. I usually install the seals on the piston and toss the whole unit into a nice cold freezer over night to shrink everything down good and also use a band-style piston ring compressor to get them started in the bore. Also make sure you replace the packings on the cylinder end cover when you go back together and torque the cap to specs.
Jason Z in MO
03-04-2007 20:20:32
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to G/MAN - I should add..., 03-04-2007 11:38:50
I'll keep your tips in mind when I get that far. Hope it's sooner then later!
G/MAN
03-04-2007 11:36:17
I tend to agree with Mike. You have very little to lose by simply honing the cylinder out well and reinstalling the piston with a new seal. I honestly doubt you're going to see a serious hitch problem when the tractor is running because of deep scoring, but it's probably going to settle down fairly rapidly when the engine is off. And seeing as how the rockshaft cylinder was never designed to keep the rockshaft up indefinitely with the engine off anyway, that's to be expected. Honing isn't going to get all those really deep grooves, but it will take care of a lot of the much smaller ones, and the smoother you can make the bore the better off you'll be. Hone it, seal it and run it would be my advice.
Mike M
03-04-2007 05:17:47
That looks pretty nasty ! Must of had alot of metal ran through it. Makes me wonder how the rest of the Hyd. system is holding up to all that metal ? As I see it you have 2 choices ? Hone it out and put it back together with a new seal and see if it helps it enough to meet your needs. Nothing really lost but your time and a little the seals cost. This will really only buy you some time for the second choice of finding another housing at a salvage yard. You may want to price this against having yours resleeved which a machine shop should be able to do ,but at what costs ? Be sure to reseat that thermal relief too. It's not going to hold up for long or well the way it is, So I guess it depends on if you can let it sit a while and you take time to find and price out a proper repair. Or stick it back together while you search.
Jason Z in MO
03-04-2007 06:24:57
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Mike M, 03-04-2007 05:17:47
third party image
The damage happened before I got the tractor so I don't know what the previous owner had repaired. However, I know the main pump was replaced. Found that out while trying to clean out the internal filter screen; my pump doesn't have one. Looking online it appears the new replacement pumps don't.
Soon after I bought the tractor I replaced the brakes and cleaned the metal out of the case, load control seals, etc. The remotes will leak down too but slowly (while not running). Steering is responsive and doesn't give me any problems. Brake valves are firm and solid while engine is running. But for manual brakes, when main pump isn't pumping, the pedal travel is huge.
While doing this work I have been inspecting everything I can get to with this stage of tear down. I pulled the transmission pump, see picture... I have a new pump ordered. I checked the filter bypass check valve, no scoring. I pulled the plug I thought was the main pump filter screen to check those parts, looks great. I can't figure out how to remove the check valve just after the transmission pump to the filter housing. Book says the 4020 should have a large hex nut but mine is pressed into the case. Without removing the differential I don't think it�s coming out. I don't have problems with leak down while the clutch is dis-engaged so I assume its ok. The other valves in the rockshaft valve housing are in good shape.
I'm not planning to open the SCV's or the priority valve.
Hours on the tractor are a mystery. The meter had around 1200 when I got it and crapped out at exactly 1500 a few years ago. Now it has a couple hundred on the new meter.
I guess a new rockshaft housing is in order. I'm sure it's cheaper than the machine work to install a sleeve.
I guess I have written enough, I'm getting depressed!
Jason
Tx Jim
03-04-2007 04:16:44
Jason,it's been since the mid 80's that I was a service manager for a JD dealer. I've seen some bores with slight scratches and we never did anything but put on a new o-ring. You might be suprised what good was done by renewing thermal relief valve. If you bored it out where would you locate an oversize piston. You could try a cylinder hone! I'm curious as to how many hrs your tach shows and are the balls on 3pt arms very worn? Tx Jim
Jason Z in MO
03-04-2007 06:31:45
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to Tx Jim, 03-04-2007 04:16:44
Jim,
Thanks for your help. Originally, I thought these were sleeved at the factory. Not the case. I guess I would have to bore and sleeve or find a replacement housing. Honing might work, can't hurt I guess!
The hours are a mystery. I replaced the gauge at 1500 hours and the new one has a couple hundred.
3point balls are not bad. The drag links where they ride against the sway blocks have some wear, maybe an 1/8th of an inch. I'm thinking about building that up to take out the play. The sway blocks were shot, They have been welded on during their life. New ones coming.
Thanks again everyone! Any good salvage yards in MO; Two Cylinder Plus?
Jason
KIP in MX
03-03-2007 22:15:32
I can't see how any seal would keep fluid from leaking past those scratches/grooves.
Just my 2 pesos worth.
Jason Z in MO
03-03-2007 22:24:34
 Re: 4020 rockshaft piston bore pic / hi-res = LARG in reply to KIP in MX, 03-03-2007 22:15:32
I thought so too and I'm sure it will leak internally some. I asked the question here a few weeks ago and a couple of seasoned JD trained mechanics said they have never seen a rockshaft cylinder that had to be replaced.
I wonder how much oil will seep past and how fast it will fall if the cylinder is the only problem.
I'm not expecting it to hold for days... an hour would be a big improvement!
