1020 running hot
Bob Nelson
03-03-2007 13:28:32
Purchased a 1020 with loader in December. It has not shown any signs of overheating until today. Ran it rather hard for about 3 hours moving about 24 inches of snow. (Yeah really!) It was running real hot; right up next to the red zone. Any ideas what it might be? I can only think of: thermostat, water pump, radiator. Had to keep it at about 1,500 RPM to stay out of the red zone. What do you think is the most likely culprit?
Bob Nelson
03-06-2007 10:32:12
 Re: 1020 running hot in reply to Bob Nelson, 03-03-2007 13:28:32
You could always see the temp gauge rise just above halfway; then "see" the thermostat open and the gauge drop to just under halfway. Now the last 2 times I've started it, it just marches right on past midway and near the red zone. So this strikes me as a sudden thing versus a gradually evolving problem. The temp gauge wavers or fluctuates a bit too. That seems like maybe thermostat to me; that isn't opening properly. I'm thinking a water pump or a radiator problem wouldn't come on that suddenly? What do you think about that theory?
buickanddeere
03-04-2007 19:28:18
Scum, slime, oil and mineral scale will bung an otherwise acceptable system. So will a few cans of "Stop Leak".
buickanddeere
03-04-2007 19:27:13
Osage
03-04-2007 05:38:54
Bob:
Let's see you bought it in December, which is rather recent, however the problem appears to be an even more recent development.
If it were me, first I'd flush the radiator and power wash the heck out of the core exterior. Then if that didn't fix it I'd check the thermostat and/or the gauge.
Osage
Al Epp Waldorf Md
03-03-2007 18:19:35
I agree with Dave, make sure your radiator is clean first. Also check your gauge. I have a 4020 that started running right up to the red so I replaced the thermostats but it didn't help at all. The next day I got up on the tractor and happened to notice the temp gauge was not all the way over on cold. Went and bought a new gauge and hit the field and it ran right on normal.
Dave Klever
03-03-2007 17:31:40
Is your fan belt tight?
I have a 301-A, which is basically an industrial variant of the 1020. It was running hot also. I hosed the radiator out as best I could. No improvement. Changed the thermostat. No improvement again. Then I pulled the radiator off and started hosing it out good. There was LOTS of stuff in there, but when the radiator was on the tractor, because of the fan etc., I couldn't get a good straight shot with the hose to clean it out. While I had the radiator off I pulled the water pump just to make sure that wasn't a problem. It was a pretty stout looking little unit and there was nothing wrong with it.
To get to the point, pull the radiator off and give it a good hosing. And if you plan on doing any dirty work like bush hogging, you should probably think about ways that you can keep all that crud from getting to your radiator in the first place. Good luck.
Gerald J.
03-03-2007 13:40:56
Thermostat, ice, waterpump, fan belt, lean mixture.
You should be able to detect coolant in motion once it gets up to normal temperature just looking in the open radiator cap.
Gerald J.
