Diesel A or Diesel G
Sunny 4 acres
03-03-2007 12:34:17
Were they ever made? I heard they were but were rare.
Ben.So.Tex
03-04-2007 06:34:48
 Re: Diesel A or Diesel G in reply to Sunny 4 acres, 03-03-2007 12:34:17
I saw a G at the show in Temple couple of years ago. It looked real but I just think someone had nothing to do. It was electric start with the started of a newer generation.
JDGnut
03-03-2007 21:44:47
There is a Diesel G in our Area.. there's been a few write ups about it.. it being some proto type machine... Its a good cross between 70D and G... Looks like a 70D, but G from the frame forward, and G rearend housing back.. (Splined axles.) It looks pretty real.. but you can take it for what its worth.. (Looked like someone 40, 50, 60 years ago, just had too much time.. and two tractors... I couldn't find any X castings???)
JDGnut
G/MAN
03-03-2007 20:02:18
I believe J.R. Hobbs' "Styled Letter Series" book makes mention of the possibility that diesel "G" prototypes were possibly built, but no, there were never production versions built. His book does make mention of the possibility that some factory gas-burner "G"s were apparently built, though. And that's another version that supposedly was "never" offered, as the "G" was always marketed and the original parts books show it as being all-fuel only.
Jerry (KS)
03-03-2007 17:40:22
The first diesel that John Deere put into production was the R in 1949.
CLW
03-03-2007 17:05:11
There were a couple of guys that pulled the original engines and put V8 engines in them for shows. Seems like at least one was a diesel, but no factory diesels were for sell. There is an A with twin gas engines somewhere in the "Tractor Photos" that I saw a year or two ago. There was talk that one of the publications were going to do a story on it but I guess it didn't work out.
Pappy
03-03-2007 13:41:47
What might be confusing is that the "A" and "G" all-fuel tractors would run on kerosene, distillate, and diesel fuel. They were carbureted engines, with spark ignition, and would run on a variety of fuels. These tractors had to be started on gasoline and switched to the heavier fuel once they were warmed sufficiently to about 190 degrees. But no true diesels.
Tom43
03-03-2007 12:53:46
Dear Sunny,
Don't believe everything you hear. Neither tractor was ever made in diesel.
