Finally been getting 4020 hot
Nylon
03-02-2007 20:26:39
Actually not hot but at least up into the middle of normal range. Hot enough to vaporize the oil off the valve cover and other oozeing spots. It never gets warm loadering, drive blading or even plowing. Snowblowing finally did it. This blizzard isn't death defying since it is warm. (relatively) The 686 deere blower does put a workout on the 4020 with this much snow. Wish 1st reverse was slower at pto speeds. It handles it most of the time but plow banks not quite. The tractor will force the blower through it but augers cant gather it up fast enough and it overflows around the sides. Speed in revrse is also a little uncomfortable when needing to manuver a bit too. Sorry to editorialize....just tickled that handling this much snow quickly and in a cab has really made the 4020 shine. Opens everything right up. I do elderly and widow farm neighbors. Plowing works great in a truck up to a point. Wind is blowing over the banks tonight which are already higher than plow can throw. So tomorrow blower in the wind in a cab :}
G/MAN
03-03-2007 07:28:31
 Re: Finally been getting 4020 hot in reply to Nylon, 03-02-2007 20:26:39
If you're having trouble getting the tractor to operating temp, you might try covering part of the radiator with a piece of cardboard. Cover more or less area as needed. There's not much harder on a diesel engine than operating "cold" for long periods of time.
Nylon
03-03-2007 09:18:19
 Re: Finally been getting 4020 hot in reply to G/MAN, 03-03-2007 07:28:31
Thanks G man. I have used cardboard. I may have to try a different thermostat. Even in the hot of summer it gets warm but on the low end of warm.
G/MAN
03-03-2007 10:44:05
 Re: Finally been getting 4020 hot in reply to Nylon, 03-03-2007 09:18:19
You might want to take your temp gauge readings with a big grain of salt, especially since you're just dealing with colored bands and no actual degree numbers. I've seen more than one tractor with an "overheating" problem that was simply a faulty gauge or sender. It might actually be running warmer than you think it is. Get it up to temp and shoot the water manifold with an infrared heat gun or plumb in a known good mechanical temp gauge to get a good idea of the temp.
Gerald J.
03-03-2007 09:24:41
Takes two thermostats. And on my 4020 gas, one did fail by opening at about 120. Two new (tested) thermostats and a couple gaskets fixed it up.
Gerald J.
Nylon
03-03-2007 12:09:56
 Re: Finally been getting 4020 hot in reply to Gerald J., 03-03-2007 09:24:41
Very good points guys. Once again thanks for the info.
TimS in Mo
03-05-2007 09:36:46
 Re: Finally been getting 4020 hot in reply to Nylon, 03-03-2007 12:09:56
I had trouble getting our 4010 up to temp earlier this winter, the kind folks here suggested checking the thermostats so I picked up to new 180 degree ones at the dealer.
Came home, took the housing off, lo and behold, one of the thermostats had come apart, luckily I could fish out the bottom portion of it. The old thermostats were 160 degree ones as well.
Put it back together with new 180 degree thermostats and a fresh gasket, now it comes up to temp nicely....and uses less oil to boot. Come to think of it, I haven't added any since I did the thermostats. Running at the right temp now must keep those old seals sealing a bit better or something....
