JD -B head
MTC
03-02-2007 13:39:11
Hey guys just pour anti-freeze into a John Deere 1936 B I just bought and want to restore.Anti-freeze pour out by the drain plug.I thought the plug was gone.Looked underneath and the plug was in.Pulled head off and found a piece about the size of 2 silver dollars broke out of the casting.Have the piece and it fits in place perfect.Would you weld (braze)it back togeather?Any advice?Thanks Mike
DickD
03-03-2007 07:46:41
 Re: JD -B head in reply to MTC, 03-02-2007 13:39:11
SORRY Paul!! I meant this for MTC
Paul from MI
03-03-2007 14:20:10
 Re: JD -B head in reply to DickD, 03-03-2007 07:46:41
Dick
Point well taken. I should have also mentioned checking the block for cracks. Unfortunately I have had some experience in that area. My 1944 B had frozen, had head & upper water pipe welded when I bought it. After several years it started leaking water into the oil. Turned out to be crack in a push rod hole in the block, but was hard to find. I have had pretty good luck repairing head cracks by plugging with cast iron tapered thread plugs. The only one I had fail was on a D, & it was into the intake port. If the block is OK, I think the head could be repaired. Again, sorry I didn"t mention checking the block as well, my oversight.
Paul
DickD
03-03-2007 07:42:31
Paul; I don't know how much experience you have, so please don't take offense to what I am saying. It would be a GOOD idea to check your block, and head THOROUGHLY for cracks, as your cracked head
might very well have been caused by the tractor freezing up. It might save tearing it down twice.
Good Luck!
Paul from MI
03-02-2007 15:40:22
I"d sure have a good repair shop give it a try. Since it"s on the outside any leak should not get into the oil. You will have to have the head resurfaced, but that"s a good idea anyway. Also ge manifold surface cleaned up & make sure your manifold is also flat while you are at it. Paul
