730 Rear wheel STUCK
Ben.So.Tex.
03-02-2007 13:38:54
I need to move the wheel out on my 730 and it will not budge, I have had hard ones in the pass, Any New Tricks?
Thanks Ben
730virgil
03-02-2007 19:51:31
 Re: 730 Rear wheel STUCK in reply to Ben.So.Tex., 03-02-2007 13:38:54
clean dirt and paint off of hub and axle. i say this as someone had welded hub to axle on my a. they did poor job of welding as friend and i broke the weld and finally got wheel to move then we saw what had been done.
donwisc
03-02-2007 14:04:10
This subject has probably been brought up more than any other on this site with alot of good advice based on experience. Go to the archives and do a word serch on WEDGES JD forum only and you will get a whole evening worth of reading and you will learn more than you you ever wanted on this subject. Good luck.
JMS/MN
03-02-2007 16:19:00
 Re: 730 Rear wheel STUCK in reply to donwisc, 03-02-2007 14:04:10
Page 8.
Ben.So.Tex.
03-03-2007 06:35:49
 Re: 730 Rear wheel STUCK in reply to JMS/MN, 03-02-2007 16:19:00
The only thing I did'nt try was the pipe trick cut at angle and slip over the axel. I have some small mesquite that I need to plow out with a root plow today maybe it will break free with bolts loose and the other two tight. Thanks Ben
