148 loader - rebuild
Dan C.
03-02-2007 08:36:36
Have the loader off for variuos reasons and was wondering whats involved in rebuilding the cyclinders? Cost and my labor involved?
The bucket and lift drifts down over time is the reason why I am considering this since I have it off.
Thanks for any help!
Nylon
03-02-2007 20:05:32
 Re: 148 loader - rebuild in reply to Dan C., 03-02-2007 08:36:36
The biggest trouble I had rebuilding is those dang snap rings. Getting them in and out is a bugger. Also you will need something with ouumph to get the packing nut to let go. Another set of hands is a plus.
Jd 40203020
03-02-2007 09:16:41
rebuild kit for each cylinder will be around $40. You will need to remove the cylinder, remove the outside(visible) snap ring. Then push the end a little ways inside the tube to remove another snap ring that you can't see. Then pull the end and the piston of the cylinder out. Replace the seals and reasemble. Not too dificult of a job, but it may be a pain to get the end to come out of the tube.
Cannonball
03-03-2007 06:32:35
 Re: 148 loader - rebuild in reply to Jd 40203020, 03-02-2007 09:16:41
you can get the same kit from baum hyd for 1/2 price or less..keep extra kits for mine here ...
MAY GOD BLESS THE USA
