3020D compression
buckeye al
03-02-2007 06:05:31
Am giving a friend some assistance on a 3020D.
His Dad is itching to wrench on it & start disassembly loosing patience as we wait for the shop manual to arrive. Tractor's problem is the weep holes are weeping anitfreeze badly. They do not know how many hours are on the tractor since majored or what the previous owner did to call it a major. They had the injectors re-built last winter which helped some but it's still a tough start. I cautioned them to run a compression check before taking it apart so I gave them my guage and he got the adapter for it (cigar injectors). What we don't have yet is any book listings for what we SHOULD see for a 1964, 3020D. I'm sure the Deere shop manual will have all we need but the owner's Dad is as I said getting itchy & wants to "get going" on the job. He's determined to remove the starter this weekend. That will make checking compression a bit challenging won't it? I know the manuals I have for my tractors say so many PSI at 200 rpm ect but I don't have a 3020 or 4020 manual.
Thanks.
buickanddeere
03-02-2007 21:27:58
 Re: 3020D compression in reply to buckeye al, 03-02-2007 06:05:31
Doing any job right is like target shooting. Ready, Aim, Fire. Not much good if somebody does ready, fire aim or fire aim ready. Same with doing any job, particularly something technical with many steps. Beware of the Ready, Fire, Aim mechanic.
Shoes
03-02-2007 12:28:32
I agree with Bob, if your leaking coolant at the weep holes, your probably going to find that your orings, sleeves, and possibly block have deteriorated to the point of needing some attention anyway. Dig in, and be sure to get your valve depth correct in the head, and you'll be amazed at the results you'll get in cold weather starting.
justfixin
03-02-2007 08:30:11
If water is running out of the weep holes, you know that it all has to come apart to fix the problem. Once you get the head off, you can get a pretty good picture of what the sleeves look like on the inside to tell if they are shot or not. Then you can look at the valves to tell what they look like. Compression checks are a waste of time because there are so many variables to a compression check: Batteries, starter condition, the speed at which the engine cranks over with the starter, etc.
Bob
03-02-2007 08:45:00
 Re: 3020D compression in reply to justfixin, 03-02-2007 08:30:11
Or, more exactly, there is probably MORE than a 90% chance the sleeves are rusted and pitted beyond re-use, since the "O" rings are leaking.
So, new pistons and sleeves, a valve job, and a thorough check of the camshaft (including oil pump drive), and it will be "good to go"!
