CHARGING SYSTEM
DOUG LEWIS
03-01-2007 16:20:38
I HAVE A 49 B THAT IS NOT CHARGING. WHEN I GROUND THE FIELD ON THE GENERATOR I GET 8 VOLTS AT THE BATTERY OTHERWISE I GET NOTHING. BAD REGULATOR RIGHT? BUT ALSO I THINK THE BATTERY IS NOT ALL IT COULD BE. WHAT IS THE MAX. VOLT I SHOULD READ AT THE BATTERY. ALL CONNECTIONS ARE GOOD AND CLEAN.ANYBODY HAVE GOOD LUCK WITH ANY BRAND BATTERY AND VOLTAGE REGULATOR? THANK YOU DOUG LEWIS ESOPUS NY
John T
03-01-2007 18:47:55
 Re: CHARGING SYSTEM in reply to DOUG LEWIS, 03-01-2007 16:20:38
Doug, a good and properly charged 6 volt battery ought to measure around 6.3 volts setting but rise to the 6.5 to 7 volts or a lil more range if coupled to a good working charging system, depends on battery condition n state of charge and charging system etc. etc.
If the battery voltage rises ONLY if you dead ground the gennys Field, that says EITHER the VR isnt well grounded orrrrr rrrr the VR is faulty (if a 3 or 4 terminal VR) or wired wrong or if its a Cutout Relay system, the light switch isnt well grounded or the wire from the gennys field post to the light switch is bad or open. CHECK THAT THE VR IS WELL GROUNDED !!!!! !!
You may wanna have the battery load tested and check its Specific Gravity, be sure theres electrolyte above all the plates and that no cells exhibit a gray or milky color????
John T
