HYD PUMP 4020
DUCKBILL
03-01-2007 15:14:39
MY HYD PUMP TURNS HARD ON MY 4020, I TOOK I OUT OF TRACTOR AND AFTER I REMOVED THE LINES IT TURNS EASY, WHAT THE DEAL IS IT MY PUMP OR MY TRACTOR?
jdemaris
03-02-2007 05:24:27
 Re: HYD PUMP 4020 in reply to DUCKBILL, 03-01-2007 15:14:39
They turn fairly hard normally since there are eight pistons with spring pressure against them - all riding on a rotating crank-journal. And, once a pump gets some wear - hydraulics will make it turn VERY hard - hard enough that it burns up starter motors. All you need is a $5 or $10 manual-pump shut-off valve - and it will turn MUCH easier.
third party image
third party image
Bob
03-01-2007 17:19:15
WHY d1d you remove 1t? NO hydraul1cs? No1sy?
1t 1s NORMAL for them to be qu1te tough to turn by hand.
DUCK BILL
03-01-2007 19:31:28
 Re: HYD PUMP 4020 in reply to Bob, 03-01-2007 17:19:15
iT WAS NOISY AND THAT WAS FROM DRIVE SHAFT EAR BEING BROKE, SO TRYED TO TURN PUMP AQND IT SEEMED PRETTY TIGHT, I GUESS TIGHTER THAN THE ONES I HAD MESSED WITH BEFORE, BUT AS SOON AS I OPENED THE LINES UP LOOSENED UP LIKE I THOUGHT IT SHOULD HAVE BEEN BEFORE
