J D front wheel bearing boss
R.J.
03-01-2007 13:49:12
The bearing bosses on my double front wheels of JD 70 are worn badly, need to be built up and turned down. My question is do the spindles come out of the upright, and how? Any help and information is appreciated.
Thanks R.J.
R.J.
03-02-2007 06:30:16
 Re: J D front wheel bearing boss in reply to R.J., 03-01-2007 13:49:12
Kurt, Mine is none rollmatic there is one rivet directly above the spindles. I am assumeing by removing this rivet would let the spindles come out of the upright in two seperate pieces would this be correct? I have the whole deal unbolted from the tractor.
RJ
Kurt_JDB
03-03-2007 05:56:04
 Re: J D front wheel bearing boss in reply to R.J., 03-02-2007 06:30:16
RJ,
I realize now of course, that you have a convertable front pedestal. I looked in my IT manuals to see what they have to say about removing the spindles from the convertible housing, and they say nothing about it. I also have a JD parts book for a B out in the shop that shows the convertible pedestal. It also does not show how it comes apart, or what the separate parts are. I am guessing the forgings are held to the shaft with rivets, but I don"t know, and the books I have don"t say how to take it apart. You could try removing the rivets, but it still may be very difficult to get it apart as it is probably a press fit.
I think it would be worth your while to get the parts book from JD to see if it has any more info. It is a really good investment if you are planning to do any more work on your tractor.
Sorry I can"t be of more help.
Kurt
Kurt_JDB
03-02-2007 04:47:51
R.J.
If I understand you correctly, you are saying that you do not have a front end with rollomatic? If you do have rollomatic, each spindle can be removed from the rollomatic housing by taking off the cap covering the thrust washer and removing the lock wire and bolts. If you do not have rollomatic, the spindle assembly is press fit and rivited to the vertical steering shaft (at least this is how it is on the letter tractors, and I beleive it is the same on the 70)
It is a rather big deal to remove, as you need to raise the front of the tractor to remove the front spindle, or find a nice deep pit.
Kurt
Kurt_JDB
03-02-2007 06:12:28
 Re: J D front wheel bearing boss in reply to Kurt_JDB, 03-02-2007 04:47:51
To continue my last message,
To remove the vertical steering spindel you must also open up the steering gear box and remove the sector gear from the top of the shaft. I think you will also have to remove the steering wheel and remove the worm/shaft out of the front of the tractor to remove the sector. A parts book and service manual would be a good thing to get.
Kurt
