Johndeere 4020 spark plugs
johndeereyellow
02-28-2007 14:18:26
What spark plugs is to be used in a Johndeere 4020 gas
Glen in TX
02-28-2007 17:09:12
 Re: Johndeere 4020 spark plugs in reply to johndeereyellow, 02-28-2007 14:18:26
Some other good ones in 18mm for gas engines are Denso L14-U or AC-Delco C88 or C87. Champion recommended UD-16 but I don't recommend those.
buickanddeere
02-28-2007 17:00:00
Autolite 3116 non resisitor and non resisitor solid wires. Keeping the coolant temp to 195F and the mixture lean will limit fouling. Manifold heat is a good idea unless working the engine hard in hot weather.
ram ranch
02-28-2007 15:42:52
I use AC or NGK
BMAN
02-28-2007 14:41:40
I used Autolite 388
