unstyled b mag
JDNPC
02-28-2007 08:40:24
got ahold of my mag for the 36'b and need a little help to determine what i might need before i go dumping alot of cash in it. it is a DRV2B serial number 110484 and jd part # AB706. the person who had it before me stated that the impulse was missing. what is that, and how can i tell if it is missing? it throws a mean spark when i jump a wire from the post to the case and i hear a click inside. the only thing i see missing is the drive gear or dog gear. where can i get a replacement drive gear, and what do i need to do before i decide to have it rebuilt or inspected professionaly. thanks
Glen in TX
02-28-2007 13:12:26
 FM Impulse Illustration in reply to JDNPC, 02-28-2007 08:40:24
third party image
Impulse as used FM J,X,XOR,DRV,RV & others.
Glen in TX
02-28-2007 10:21:18
 Re: unstyled b mag in reply to JDNPC, 02-28-2007 08:40:24
third party image
If it clicks and throws a good hot blue spark sounds it should all be there. The impulse is on drive end consisting of a drive cup, spring, hub assembly with trip dogs that is keyed to the tapered shaft and trip dogs hit a hardened pin that screws into housing all held on shaft with a nut. All mechanical parts that can wear, crack or spring can rust and get weak. There was a early W series FM impulse used originally on the RV mags which the drive cup and hub is more squared off but the later newer UA series FM impulses that are rounded off in shape some will fit and interchange also. New drive cups and hubs are pricy but I still have some NOS and used ones available if it is missing.
