3010 John Deere
RBoy
02-28-2007 06:40:28
I have a gas 3010. It sputters and cuts out when being used. I found if I pour hot water on the carb periodically it runs fine (like it's a vapor lock)... What can I do to cure this problem?
Bob
02-28-2007 06:56:04
 Re: 3010 John Deere in reply to RBoy, 02-28-2007 06:40:28
Is the "seasonal changeover" on your manifold set up for winter use... manifold pre-heat?
Have you dumped some "dry-gas" in the tank?
RBoy
03-16-2007 09:58:52
 Re: 3010 John Deere in reply to Bob, 02-28-2007 06:56:04
I put cans and cans of Seafoam through it...I'll have to check the manifold, is there markings on it as to which position it should be in for winter?
