4020 transmission filter
deeredoug
02-27-2007 18:40:45
Can you change the filters on a power shift Tran.
with out losing a lot of fluid?
Thanks dougc
justfixin
02-27-2007 19:51:19
 Re: 4020 transmission filter in reply to deeredoug, 02-27-2007 18:40:45
you dont have to drain the the oil out, you will only loose about 2 gal at the most,if you are just doing a yearly change and dont have hydrolic problums than dont wory about the screen.
Nylon
02-27-2007 18:46:14
You are going to have to drain the reservoir before pulling filters or you will loose it on you and the floor. Drain it into 3 white 5 gallon buckets. Look for settled debris or fines. If not too bad, run the fluid through a milking filter or similar and reuse. Also pull screen and check / clean while drained.
K.B.-826
02-27-2007 19:53:34
 Re: 4020 transmission filter in reply to Nylon, 02-27-2007 18:46:14
No need to drain the oil if you're just changing filters. You'll loose about 3 quarts out of each filter housing at the most. If you're going to remove the suction screen, then of course you will need to drain all of the oil.
