410-D backhoe oil pressure
davids
02-26-2007 18:12:18
Rebuilt engine, new crank, bearings, oil pump and all the other required parts. Oil pressure is 35 psi when cold or hot at idle. About 40 psi throttled up. Is this enough or should I bump it up a little? Thanks, davids
MSM
02-27-2007 01:33:52
 Re: 410-D backhoe oil pressure in reply to davids, 02-26-2007 18:12:18
40# is plenty,if you raise it,you may encounter oil consumption problems.
