Break In
Jake JD
02-26-2007 17:59:12
Getting ready to put in a new set of rings on grandpas jonnypopper. whats the best way to break them in so they seat properly, as the same for the rest of the bushings and new bearings? looking for advice from the people who have done it. thanks Jake
justfixin
02-27-2007 20:06:07
 Re: Break In in reply to Jake JD, 02-26-2007 17:59:12
I use northland brakein oil its a lot cheeper than deere oil, thay make deeres oil.
buckeye al
02-27-2007 14:32:31
Every time I ever installed Deere rings (in these old two cylinders) there was a little green card in the box that told what to do. I have kept one of those in the shop for years & know right where it is. Unless there is some otehr set of instructions in the new box of rings, I follow that card's instructions be it an IH, AC or JD.
I'm not quoting because it's not here in front of me but seems they say something about using either Deere Break In oil (preferable) or a good 10 weight non detergent oil. Start & run for 10 minutes at slow idle then 10 minutes at fast idle. For the next 20 hours (maybe 25) run at operating temperature, at varying speeds but never more than 3/4 rated load. Change the filter and oil to what is recommended in the manual and let her rip.
I've never had an oil burner nor a re-do. I always figured they knew more about them than I so I follow THEIR instructions!
Through the years and different articles I've read (JD, GM & Perkins), I've been led to believe that varying the speed through the break in period is very important! Maybe more so than the less than 3/4 load limit.
Have heard many an old timer say best thing to do is hitch it to a plow and run it hard and hot. I've never seen such instructions from any engine manufacturer so I don't subscribe to that method at all.
G/MAN
02-27-2007 15:51:43
 Re: Break In in reply to buckeye al, 02-27-2007 14:32:31
You should probably update your break-in procedures to keep pace with what Deere is currently reommending. Recommended break-in procedures have changed nearly constantly over the years. Current break-in instructions for a Deere 6081 HPCR engine in an 8520 tractor after major overhaul are 1 minute at low idle and no load, 1 minute at fast idle and no load, 15 minutes at 1/2-3/4 load at 2000 rpm to rated speed (2200 rpm), and 10 minutes at full load. Also recommened is a maximum run time of 100 hours on the Break-In oil and an addional 100 hours on Break-In oil if the engine has had significant time at idle, has been only lightly loaded or exhibits excessive oil consumption during the first 100 hours. We wouldn't conceive of sending a tractor out with a fresh engine with less than a couple hours at full load at the bare minimum, because you simply can't guarantee how the owner will operate the tractor. If he takes a fresh engine with no on-dyno break-in home and putters around the yard doing light-load work, it's almost a guarantee that the engine will be back for excessive oil consumption and blow-by. As oils have improved, the need to work the engine hard during break-in has come about.
buckeye al
03-02-2007 14:24:01
 Re: Break In in reply to G/MAN, 02-27-2007 15:51:43
Understood and perfectly sensible and logical. Will likely work the next one a bit harder!
Also, the ring sets I have been using are left over NOS from a dealer that went out of business some 25 years ago. These kits were old when I bought them! I still have one or two of the factory all fuel to gas conversion sets for A's. I will keep what you say in mind on the next one I overhaul but.....
Would and A live through 15 minutes at 2000 to 2200 RPM??? Would I want to stand 'round to be witness to it?
Only funnin!
Later.
G/MAN
03-03-2007 20:17:19
 Re: Break In in reply to buckeye al, 03-02-2007 14:24:01
I understand completely. I figured your break-in instructions were probably included with some older parts. Break-in issues are a combination of improved machining and the high-quality oils these days. And I don't know that I'd recommend beating on a two-cylinder the way we do the multi-cylinder engines, but a good workout sure won't hurt anything. My theory is that if you seat the rings well enough that they'll do a good job of sealing the cylinders at full load with maximum cylinder pressures, they'll certainly be trouble-free at any other engine speed or load conditions. I've even seen specific instances where Deere has recommended taking an overhauled engine down to 1300 rpm and holding it there for 1 or 2 minutes to really put the squeeze on the rings, and I've done it, although it's kind of an odd feeling. Not much different than doing a torque-rise pull, but doing one of those you normally don't hold 1300 rpm for any length of time. It also takes quite a bit of dyno to suck an 8400 down to 1300 and hold it there. We've got an AW Nebraska 600 (600-hp capacity) that does the job fine. With our water supply we can pull 375-hp continuously. I know it used to be common to "baby" a new or overhauled engine to a great extent, but obviously Deere has run into enough problems that they absolutely don't want that happening these days. My thought is that once the engine has run for a few minutes, everything is working properly, it has built some heat and has no problems, it's time for it to go to work. I actually like to do the initial startup, allow it to run for a few minutes to warm up some, run it at higher speeds to get the lifters rotating, let it cool for a few minutes and then shut it down and allow it to cool thoroughly overnight. The next day after a checkover and fluid check, it goes outside and right to the dyno. I vary speeds and loads as much as possible without standing there and baby-sitting it all day, and frequently go out to pull it well below rated speed, unload it and allow it to go to high idle for a few minutes, back down to near rated and so on for the entire period its on the dyno. And several times I'll go out and pull it down quite a ways. It's all personal preference and some do it differently, but I've overhauled 15 or 20 tractors that way in the last several years, everything from 3020s to 8000s, and haven't had an engine come back on me yet.
G/MAN
02-27-2007 07:34:42
As buickanddeere said, you need heat and pressure to seat rings, along with a good straight and round bore, the proper crosshatch and new rings. Only place I'd differ with him would be the temperature and load - I'd shoot for 200 degrees or so and would pull the tractor down to full load, after checking to make sure everything is working okay and that there are no major leaks, etc. I'd also definitely use Deere Break-In oil - it's factory fill in all new Deere engines and pretty much a necessity for overhauled engines. Today's high-quality diesel oils have tremendous anti-wear additives that can preclude a good break-in regardless of load and length of the break-in. The Break-In oil is a 10W30 oil with a much lighter helping of anti-wear additives in order to promote ring seating. I saw 20 hours mentioned below, which is probably going to be hard to get to in any reasonable length of time with an old non-working tractor. We actually tell customers with new and overhauled engines to run Break-In oil for 100 hours, dump the oil and change the filter and refill with Break-In for another 100 hours. We also try to run overhauled engines for a minimum of 4-5 hours at full load, but of course that's on post-1960 tractors. What you absolutely don't want to do is put-put around at little or no load and/or let the engine idle excessively.
buickanddeere
02-27-2007 04:47:32
If the bore is tapered and egg shaped the rings will never truely seat and seal. However new rings will likely seal better than old worn down rings. If the piston ring grooves are worn the rings will tip and not be held square to the bore. Sealing will be impared. You will have to measure the bore and find the location withn the smallest dia and set the end gap there. In areas where the bore is worn more the end gap will increase and blowby will increase but can't be helped. The ring groove at the top of the bore will have to be machined away or the new top ring will run into it and be damaged. It will likely be better but don't expect a "new" engine. New valve guides will be required or the new valve job will be rapidly burned and pounded away. Do you have a service manual with the clearances and torque values? Gas, LP, all fuel or diesel? Breakin will not occur unless the engine is up to at least 180+F , operated at full rated rpms and at 1/2 to 2/3 load.
ram ranch
02-26-2007 20:26:04
jake i'ved used the john deere break in oil and had very good resalts, than changed to the new torq-gard plus 50 if you don't want to use that just buy some cheap lite oil from tsc, than swich to the good stuff.
Dan in Ohio
02-26-2007 18:50:23
Jake, I bought a new compact utility tractor this past fall and the JD dealer told me the tractor would be delivered with break in oil in the crank case. They advised me to change it after 20 hours of use to the recommended wt oil. I would do the same with one of my old ones.
F-I-T
02-26-2007 18:45:58
Break the glaze properly. Get a proper corss-hatch patter. A lot of people don't do that and they have problems for months. I also favor using the JD brand break-in oil. I've used it on four majors now, and it has performed very well.
Frank
