4020 gears wont engage
hank n tx
02-26-2007 17:16:10
fired up the ol 4020 today and couldn't get it to go into any of the gears. grinding. every thing was fine the last time i used it back in october.anything i can do besides replacing the clutch? the trans is a synchro
thanks hank
msb
02-26-2007 19:41:55
 Re: 4020 gears wont engage in reply to hank n tx, 02-26-2007 17:16:10
Could be a clutch operating bolt has broken.If that is what has happened, you won't "break it loose".It was a common problem on the old 10 series.
Mike M
02-26-2007 18:49:52
Get it going up into the higher gears on a nice safe level place and then hang on to the steering wheel and stab one brake at a time while holding down the clutch pedal too, and it should soon break free.
hank n tx
02-26-2007 17:56:28
yea, i had a 80 suziki mortorcycle that did that over the winter and i started it in gear and had the front wheel against the barn and revved it up and popped the clutch and unstuck the clutch. ill try that . thanks hank
gurneejoe
02-26-2007 17:23:42
It sounds like the clutch disc has rusted to the flywheel or pressure plate. I've seen this on farmalls a few times. If the tractor is stored in a wet place it isn't a bad idea to block the clutch pedal down to relieve the pressure on the disc during storage.
jddriver
02-26-2007 17:42:01
 Re: 4020 gears wont engage in reply to gurneejoe, 02-26-2007 17:23:42
I have broke them loose (if it is in asafe spot to do)by startin em gear and pushing in on the clutch and steppin on the brakes
Gerald J.
02-26-2007 18:45:32
 Re: 4020 gears wont engage in reply to jddriver, 02-26-2007 17:42:01
They break loose better in a high gear, but starting in gear is easier in a low gear. Last tractor that did that to me, I put the front against a tree and polished the clutch in high gear until it almost smoked, then it didn't stick anymore.
On the 4020 you also need to be sure the freee pedal isn't too much. 1.5" with the engine running is the specification. If its too much you won't get the clutch released.
Gerald J.
