4020 splitting stands
regan
02-26-2007 12:28:12
I recently built a set of stands for a 3020. They are built after the same pattern as the original ones as near as I can remember. Just wondering if the rear section , the piece that bolts to the final drive will work on a 4020. Maybe the housing on a 4020 is wider than the 3020?
ET
02-26-2007 12:55:18
 Re: 4020 splitting stands in reply to regan, 02-26-2007 12:28:12
I think the 3020 and 4020 were the same width. It was the 3010 that was narrower and you used the spacers.
regan
02-26-2007 13:22:57
 Re: 4020 splitting stands in reply to ET, 02-26-2007 12:55:18
Oops!! It was a 3010 that I built the stands for, not a 3020.I may have to rebuild!!
Ray
02-26-2007 16:21:19
 Re: 4020 splitting stands in reply to regan, 02-26-2007 13:22:57
I've got a rear set i've never used,i like a floor jack better on the rear.Mine were otc brand that i bought at a jd dealer close out sale several years ago.
ET
02-27-2007 04:54:34
 Re: 4020 splitting stands in reply to Ray, 02-26-2007 16:21:19
I find that a floor jack is often the easiest route for the rear end also.
