JD #5 Mover Tag location?
Courtland
02-26-2007 07:30:00
if the number 5 mower has a serial/id tag where would I look for it?
James Howell
02-26-2007 10:25:12
 Re: JD #5 Mover Tag location? in reply to Courtland , 02-26-2007 07:30:00
Since there are no serial numbers for the #5 mower, here are some of the differences I have found on the older mowers.
The lower cover on the housing has the embossed logo.
The complete lifting and tilting lever sector appears to be �pressed� instead of �cast�.
The tilting sector is welded instead of bolted.
The box bushing on the sickle pitman has needle bearings.
The steel guards have the JD stamp on top.
The rear knife head guide is �cast�.
I have a 1936 manual by the John Deere Harvester Works. The manual has the directions for setting up and operating the John Deere Power Mower (Caster Wheel Type). On the cover it shows a solid steel tail wheel.
55 50
02-26-2007 07:57:26
There is no serial number on those mowers. You can get a rough idea of age by looking at the Parts Catalog. They were made from 1934 to 1957.
Bob
02-26-2007 07:40:25
AFAIK, NO tag, certainly not on the older units.
