FH rears
JDNPC
02-26-2007 04:46:29
the casting number on F&H rear hubs on my 36 b have the letter c at the end of it to read hc177c . is this just a variation of the original hc177? thanks in advance.
Duane Larson
02-26-2007 16:31:14
 Re: FH rears in reply to JDNPC, 02-26-2007 04:46:29
JDNPC,
What size tire is on your rim, and is the rim flat around the spokes? Most HC177C hubs I have seen have either 8W-38 or 9W-38 wide-base rims, but I have also seen a 10W-36 rim on that hub. The HC177 and HC177D both have 6.00S-36 conventional rims for 9.00-36 tires. The wide base rim came out in 1939 and was introduced by Goodyear. It would have had a wide-base 9-38 or 10-38 tire on it (or in the other case above a 10-36 or 11-36 tire).
JDNPC
02-26-2007 18:04:12
 Re: FH rears in reply to Duane Larson, 02-26-2007 16:31:14
duane, it measures 9 in outside to outside and is on a 36 in tire ( i say 36 in because when i picked up the tractor in kansas, there were no tires, just rims, and it measures 38 " across). they are flat across except for the last inch or so for the bevel. they are on a 36 b 10 spline
f&h hub with 20 spokes. the odd thing is, the original rim had a larger spoke pressed in the rim, someone cut them off and welded this hub in, or so it looks. they rotated the rim about 3" and then welded the smaller o.d. spokes back to the rim. couldn't find anything as far as markings on the outer rim itself. i'm just trying to put together a decent set of round spokes to run around on, nothing really showroom or remotely flawlessly restored.the hubs are in great shape,and spoke to the hub are factory pressed. but i'm lacking a better looking job of attaching the spokes to an unknown set of outers. just need some advise. and like always, don't want to refinance the house or sell the first born to make it happen ...thanks
Duane Larson
02-26-2007 19:51:07
 Re: FH rears in reply to JDNPC, 02-26-2007 18:04:12
Yes, there were some later round spoke wheels with 7/8" spokes as opposed to the 3/4" spokes I believe are sticking out of your hub. I suppose fluid or something caused the rims to go bad and someone welded on what was available. I'm not sure what to advise you - make them look as good as possible I guess, or perhaps buy some new 36" rims and reweld your spokes to them - or cut off the remaining stubs.... . As you may be aware, Detwiler sells very nice reproduced round spoke rears for your B - I think they are around $1800 a pair if you decide to go that route.
