JD 4020 battery box location
Greg Peters
02-25-2007 18:53:48
I'm adding a 158 loader to my 4020. This means the battery must be moved from current location next to engine on left side. It looks like original batterybox location was inside the left rear wheel. There are brackets there and box would fit, except clearence to floor plate is too small. Any hints?
Thanks,
Greg
Glen in TX
02-25-2007 21:47:27
 Re: JD 4020 battery box location in reply to Greg Peters, 02-25-2007 18:53:48
The original long narrow batteries fit in boxes under the floor plate on each side of trans. You can get those boxes new from JD yet and many aftermarket vendors have them too. There are also some aftermarket battery boxes that fit under floor plate on each side from aftermarket that are modified so a wider 12V will fit in also.
