4020 load control leaks... continued...
Jason Z in MO
02-25-2007 18:42:09
Well, today I finally pulled the load control shaft and dropped the wishbone. If you recall, that's why I started this project!
After I removed the seals and wiped out the bores the right hand bushing slipped out with my fingers! Jim, I think this is what you were talking about. JD recommended limiting the number of bushing replacements to prevent wear on the case? I hope I can find a solution without replacing the case! It's not sloppy in the bore but obviously not tight either.
Will loctite bearing retainer work here? I think it does a good job of filling gaps.
The shaft is a slight groove at the bushing location and a wear point at the spot the load control arm makes contact.
When I did this job the last time, I didn't replace the shaft. I will this time.
I appreciate any advice!
ET
02-26-2007 12:27:35
 Re: 4020 load control leaks... continued... in reply to Jason Z in MO, 02-25-2007 18:42:09
Check how worn the center front pin and bushing are in the yoke. As that pin and bushing wear it allows the yoke to try and bend the load shaft farther than it's ment too. This can cause seal failure. Red loctite is worth a try on the loose bushing. Put enough shims between the case and wishbone to eliminate all the side play. I try to get it tight enough that it takes a hydraulic jack to push it back up in place.
lonzo
02-26-2007 01:41:09
i hope that the cutting tool is useable, last time i saw one it was worthless, My Deere dealer has brand x bushings and seals that really work well, i refuse to in stall JD seals and bushings because in week or so they start leaking again and i half to redue the job only this time i use brand x and they are good for 3 years and up.
Glen in TX
02-26-2007 09:54:16
 Re: 4020 load control leaks... continued... in reply to lonzo, 02-26-2007 01:41:09
Boling aftermarket seals. Some JD dealers actually carry them too and recommend them. Used them several times with good luck but no magic seal is going to fix the bushing, shaft or wishbone and pin wear.
Glen in TX
02-25-2007 21:41:37
Like matthies said there is a tool to cut housing out for the oversized OD bushings and check parts catalog and see if they are still available. The OD of oversize ones should be in parts catalog or shop manual so measure yours to see what you have in it now. Put bushings in wishbone or fixing those worn holes too and replacing any worn pins and use shim washers if needed too between wishbone and bushings on shaft to keep the play out.
matthies
02-25-2007 19:47:19
Deere and other suppliers have steel epoxies for those loose bushings. Clean it good and center punch it a bit then epoxy and hold it in with a redirod and washers overnight aleast. If that fails later in life then contact your local Deere dealer and they have a traveling tool that gets mailed around the country to cut out the housing for an oversized bushing. chris
