Oh Deere! I need HELP with my '45 JD A!
Bewildered
01-03-2000 04:46:32
Had to take the governor off my JD A yesterday to determine what parts need replacing. Followed instructions in I&T manual, including removing crankcase cover and disconnecting oil line to governor. Once the governor was off, looking into the crankcase the strangest optical illusion made it look like the oil line that had been attached to the governor was smack in the way of the crank. This, of course, couldn't be, since the crank turned just fine before I removed the governor. Still, just to be sure I slowly turned the flywheel until, yep, the crank ran right into that oil line. I thought maybe if I moved the oil line a little this way or that the crank would clear it, but the oil line, having to come up and meet the connection on the governor, can'
t be moved much, and I couldn't really see where it could go so as to be out of the way of the crankshaft anyway. Where did I go wrong? What do I do about it?
Spokerd1- left part out
01-03-2000 07:16:23
 Re: Oh Deere! I need HELP with my '45 JD A! in reply to Bewildered, 01-03-2000 04:46:32
That line is from the oil reg and pump. You will need to drain the oil to get to it.
Spokerd1
01-03-2000 07:13:01
That oil line goes to the oil pump. you may have to loosen the oil line then when you put the govenor back on fit the line to the govenor and then tighten both fitting after you tighten down the Govenor. I&T will get you lost. If you want a manual for your tractor call 1-800-522-7448 and order the factor manual for the A. Dont order one from A deere dealer it will cost you about 30 % more. Order it direct form Deere
