G Head removal Help
larrystg2
02-25-2007 08:17:00
Can the head be removed from the tractor with the manifold still on and without removing the fan shaft and upper water pipe?
DickD
02-25-2007 11:41:52
 Re: G Head removal Help in reply to larrystg2, 02-25-2007 08:17:00
Larry; DW has a pretty good memory. I just happened to have my IT manual beside me, and I looked to see what it said. Take out the top 4 headbolts, and then turn the head so that the left side is toward the radiator. Then, just roll the head out the right side. Like DW said, "CAREFULLY."
DW
02-25-2007 08:37:34
Yes it can, I don't have my shop manual here at the house, but it tells which way to turn or twist the head to take it out. Its been several years since I had the head off of mine but I'm thinking that I removed the top four head bolts from the head to get clearance. Be very careful of your fingers, as that head is very heavy and will smash those fingers that get in the way. I think the final exit is out the pulley side of the frame with the valve springs up. Hope this helps. Dale
