4020 alt conversion
Donniehunter
02-25-2007 07:56:27
i have an early model 4020 (64?), i want to change it over to a 12 alt system.. i have a late model 6600 with a 404 where i was able to get the starter and alternator.. i need to find out how to wire the alternator and starter so they will work as a 12volt system.. does anyone have that information
Gerald J.
02-25-2007 10:47:55
 Re: 4020 alt conversion in reply to Donniehunter, 02-25-2007 07:56:27
Since the loads other than starting and charging have the tractor wired as two 12 volt systems, one negative and one positive, I'd just connect them in parallel. Remove the batteries first. Connect the wiring harness leads from the ungrounded battery terminals together. Connect up starting and charging for 12 volts and it all works, unless the fuel gauge is polarity senstive. Some say it is, though mine still works (after repairing the sending unit) when I changed my gas '68 4020 from positive ground to negative ground when I changed over to an alternator.
Gerald J.
