2010 Synchro-Range Transmission Missing gears
JHA
02-25-2007 07:38:20
My 2010 will not go into 2,4,6,8, gears. The gears will grind alittle and then it pops out. It will go into 1,3,5,7, and reverse. I have checked the linkage adjustment and it is okay. Any help will be appreciated.
JHA
02-26-2007 16:37:15
 Re: 2010 Synchro-Range Transmission Missing gears in reply to JHA, 02-25-2007 07:38:20
Thanks, I will look into both suggestions and hopefully get it fixed.
2cylfarmer
02-25-2007 18:45:38
I have a 2010 that used to do that very same thing until we put in new syncronizers.
Jim Poletti
05-14-2007 19:16:44
 Re: 2010 Synchro-Range Transmission Missing gears in reply to 2cylfarmer, 02-25-2007 18:45:38
I got a 2010 too that gears 2,4,6,8 just grind and do nothing. What does it take to put in syncronizers and do they still make these parts ?And that other fella mentioned detent balls being worn, where are these ? Jim
msb
02-25-2007 16:13:00
Sure sounds like the linkage is out of adjustment to me.Pull the detent balls and see if the detend holes in the shifters are really centered with the detents.The shifters will someimes wear and make you think the detents are where they should be.
