My plan for a quick repair of the load control leaks and rockshaft have turned into a little more...I noticed the front PTO shaft was leaking as well so I pulled the bearing quill. So now that I have this apart I thought I would try to find the source of the noise the PTO makes while under load. It had a howl or growling sound when running a mower and is under medium to heavy load. The bearing in the front quill is fine. The rear quill, bearing, and shafts all seem fine. However, the front PTO shaft has some up and down movement. If I was to guess, 1/32 of an inch at the end of the shaft. I will be back in the shop tonight and try to measure it. I'm not sure how much lateral or vertical play that bearing should have or if it would be the cause of the noise. I realize the front bearing/quill would provide additional support but could this be the reason the seal failed? I did find the front quill had fescue seed packed into the shaft and housing. I originally thought it was the cause for the seal failure. This is why I'm looking for a front PTO cover. The service manual says to remove the entire PTO shaft you have to split the tractor and drive the shaft out the rear. From what I can see, it looks like you can pull the PTO shaft without splitting the tractor. Am I missing something? Thanks to those who take the time to read my LONG posts! Jason
