Chrome or stainless straight pipe - 720
Tom Edwards
02-24-2007 15:58:48
Hi, I want to get a straight pipe for my 720 D. I see both Chrome and also Stainless, both seem to be double walled and the price isnt much different...what is the best one in terms of durability.
Also, I think 24 inches is kinda short - what do you think about a 36 inch pipe? also, what about the ones with the curved top? Do the curved top ones give the same beautifulllll sound?
Thanks@!
zwr
02-24-2007 19:16:29
 Re: Chrome or stainless straight pipe - 720 in reply to Tom Edwards, 02-24-2007 15:58:48
"Chrome" implies that the item is made from mild steel (less expensive), then plated with bright nickel and a thin layer of chromium over the nickel. "Stainless" implies that the item is made from a rust/tarnish resistance alloy (more expensive), probably without any plating.
Repeated cycles of heating/cooling are taxing on plated finishes. However, the plated item may well be more lustrous, at least to start with.
msb
02-24-2007 19:06:37
Hot chrome will bubble if hit with cold rain water. Been there--done that. Go with stainless.
WeirdDeere
02-24-2007 18:53:55
Stainless all the way. Just as shiny as chrome, and MUCH tougher! Steve Crum makes the stainless pipes to your dimensions, so he can make it the height you want, and curved if you want. The curve makes the bark seem to be louder (in my opinion) because the noise isn't going straight up.
I had a chrome pipe on my 80 and it started rusting on the base and moving up in a year or so. The current stainless pipe is doing just fine. I'm not going back to chrome!
Brandon
Brandon
ram ranch
02-24-2007 16:05:06
i like the straight myself but you don't want to leave it out in the rain i had one on my G which was great but after a day of plowing it didn't take long to remove it i might even have one on my shelf i could sell
