820d
rvopata
02-24-2007 12:10:40
am getting ready to start wiring on this beast and noticed that it is supposed to be positive ground.was wondering why?and if i could go ahead and wire it for negative ground?what kind of problems that i might expect?thanks rudy
Glen in TX
02-25-2007 07:06:08
 Re: 820d in reply to rvopata, 02-24-2007 12:10:40
Think it had something to do with someone having a idea there was less corrosion around battery using + ground? The automotive industry was first to go with negative ground and that also changed which side of the points in a battery distributor were + or - and guess they saw longer life with it set up as - ground so things went that way then?
rvopata
02-24-2007 23:43:44
am keeping it all original glen,was just wondering why they did pos. ground.i have the v-4 pony start just like all the minnosota boys and think it is the cats meow for starting in the winter time but sure does have a lot of extra parts to maintain.was wondering if anyone could show me a picture of the original battery box and hold down straps under the seat as they seem to be missing on mine thanks a million boys an girls. rudy
Glen in TX
02-24-2007 21:29:45
All the two cylinder JDs were originally postive ground and just they way many things were back then not just JD. If the regulator is a type for positive ground only and you change to negative can burn points out in it. Some regulators were universal and would work with postive or negative ground either way. You have to switch the wire on ammeter posts around also. Still have to polarize the generator either way when done and there can be same problems running either ground polarity. Why going negative? Alternator? Is yours a electric start or pony start? No real advantages either way unless your wanting to use a modern alternator and run some 12V neg. ground accessories.
