4020 Rockshaft (3-point)
Jason Z in MO
02-23-2007 22:42:02
I've torn into my 4020 to fix the load control seals and rockshaft settling problem.
A few years ago my brakes went out and filled the transmission with metal shavings. I replaced the load control seals at that time but are leaking again. Probably made a mistake the first time or more filings got into the seals. I did replace with o-ringed bushings.
The other problem I'm working on is the rockshaft. While the tractor is running it will hold a load without a problem. As soon as the tractor is shut down the arms begin to fall. I pulled the rear piston cover off and found the piston in good shape, I can't see any flaws in the o-ring but the rockshaft housing cylinder bore has some pretty bad grooves. I can hang a finger nail in them. I'm assuming this is my problem.
These cylinders are part of the rockshaft housing and are not sleeved. What's the best way to repair the cylinder? Have it sleeved???
Thanks!
Jason
msb
02-24-2007 19:18:56
 Re: 4020 Rockshaft (3-point) in reply to Jason Z in MO, 02-23-2007 22:42:02
Jason, we were taught in service school a long time ago to reseat the thermal relief vaalve by placing a punch on top of the valve and tapping it with a hammer.Be sure to blow out the seat before reseating the valve.You might want to add a shim mor vtwo to the spring. Could be some of those old shavings have messed up the seat. I too, have never seen a bore scored so bad that a new o-ring would not hold the arms up.
Jason Z in MO
02-24-2007 19:48:20
 Re: 4020 Rockshaft (3-point) in reply to msb, 02-24-2007 19:18:56
msb,
You and Jim are sure making me feel better about the rockshaft bore!
The tip of the thermal relief valve is scratched and grooved from the tip through the seat area. As a matter of fact, it looks like the tip might have been seated as you mentioned by the way it looks.
My shop manual is in the shop right now so I don't have the reference. The thermal relief valve didn't have any shims. The other valve, don't recall the name but the manual makes a reference to it being the cause of settling, had several washer shims; 5 or 6 as I recall.
How do you determine if a valve needs shims or not? I haven't read that section of the manual...
Sure wish one of you JD techs would write a book! The shop manuals just don't cover the IMPORTANT little tips.
Thank you!
Jason
msb
02-24-2007 19:52:58
 Re: 4020 Rockshaft (3-point) in reply to Jason Z in MO, 02-24-2007 19:48:20
The thermal relief valve spring setting is not critical since it is operated by temperature of the oil.Adding a shim or two may or may not help,but it would not hurt to try to see if that cures the problem.
Jason Z in MO
02-24-2007 20:04:56
 Re: 4020 Rockshaft (3-point) in reply to msb, 02-24-2007 19:52:58
How about that book?! You and Jim can team up!
Tx Jim
02-24-2007 04:07:48
Jason,in my years working at JD dealer I don't remember ever seeing a RC cylinder needing boring but yours may. Two other likely sources for 3pt leak down are bad thermal relief valve and RC control valves not seating properly or adjusted in correctly. On L&D shaft be sure and shim out side to side motion. Tx Jim
Jason Z in MO
02-24-2007 07:12:10
 Re: 4020 Rockshaft (3-point) in reply to Tx Jim, 02-24-2007 04:07:48
Jim,
Thanks for the tips! Have you seen scoring in the cylinder? I will see if a couple pictures of the bore will show what I'm talking about. I sure hope I don't have to repair it! Don't tell anyone but I did consider using JB Weld to fill the grooves to create a smooth surface.
On the load control shaft, I should shim to prevent latteral or side to side movement? As I recall, I haven't pulled it part yet, there are some caps on each end with a single bolt securing them. I don't think they fit very well and just kinda flopped around. I will look closer this time. This is probably why they are leaking again!
Thank you!
Jason
Nylon
02-24-2007 15:01:21
 Re: 4020 Rockshaft (3-point) in reply to Jason Z in MO, 02-24-2007 07:12:10
Jason,
I am going to have to do my draft seals & bushings also. I have the seals/ bushings but dont have the load shaft itself. Was thinking that I would want to just put in a new one if I was going to pull it out. Found out that the shaft is pricey so now I have yet to do it. The guys here told me that there are different thickness shim washers to take up the side to side slop in the harness / shaft. I need some of those too.
If you find a good source for those shims let me know so I can get some. Also let me know what your shaft looks like when you get it out. Want to gauge if I can just replace bushings. I have yet to run tractor in any setting other than Depth. Also would you post a pic of that rockshaft piston and seal area. I need to look into mine as well. My arms hold up pretty good and some times stay up with drawtoolbar on for days. With snowblower on it will hit the ground in 10 minutes. Want to head off any trouble down the road.
John
Jason Z in MO
02-24-2007 18:35:18
 Re: 4020 Rockshaft (3-point) in reply to Nylon, 02-24-2007 15:01:21
John,
I did the load control seals several years ago and the job isn't bad. The oil is really the only messy part. The only challenge I remember is getting the bushing out. I used a length of pipe inserted on one side to drive the bushing out of the opposite. At that time I didn't replace the bushings in the draft arms support yoke. I might have to tackle that one this time. I did move the wheels out on the end of the axles to provide enough clearence. That was a MAJOR chore the last time. This time it was a breeze since I had cleaned all the threads and replaced bolts that needed it. I've been working on the tractor today but haven't climbed under to work on the load shaft. When I do, I will take some pictures.
I did find a problem with the rockshaft settling problem. I think it's called the temperature relief valve. The little check valve tip is very worn. Haven't inspected the rest yet.
While I had the rockshaft off the tractor I pulled the transmission oil pump. I have some wear on the idler gear shaft and bushing. The shaft and gear bushing are pretty scored.
I took so pictures of the rockshaft bore. I will try to download them later tonight.
Sure wish I knew what I was doing! LOL!
Jason
Tx Jim
02-25-2007 05:08:28
 Re: 4020 Rockshaft (3-point) in reply to Jason Z in MO, 02-24-2007 18:35:18
Jason,JD recommended changing L&D bushing only if needed to keep from damamaging trans. housing with multiple bushing changes. Various thickness shims for wishbone are available from JD. Tx Jim
