Glen in Texas.
Patrick Mosset
02-23-2007 20:11:05
On the flat base Edsin splitdrof mag there is a little lever on the front side of the mag,I was wondering, down is the implus and up is free wheeling,when the tractor is running do you leave the leaver down or put it up?also when the tractor is running can a fellow move the retard arm ahead ?This is the first time I have played around with this kind of mag.Thanks Patrick
Glen in TX
02-23-2007 22:04:27
 Re: Glen in Texas. in reply to Patrick Mosset, 02-23-2007 20:11:05
It's all covered in the DIR108 Instructions & Parts List for D 30,400-119,099 still available from JD Publications 800-522-7448.
Yes, impulse pawl lever should be down to engage impulse for starting. If not worn, working right and lubed some should kick out on it's own when engine starts and engine speed increased.
Manual tells you to set throttle and spark levers both vertical for starting. After engine starts you move the right hand spark lever clear back towards you to the retard position when idling to warm up engine. Set spark lever clear ahead away from you to advance position when pulling a load. Pull the spark lever back in when idling down before shutting off engine by turning off fuel valve running out of fuel.
