720 bowl diaphragms
Mixman
02-23-2007 16:15:15
I am working on a John Deere 720 gas that is not getting gas. If I push on the button on top of the sediment bowl and fill the carb it will run until it runs out. I have checked to make sure there is good oil pressure to it. Now I have removed the assembly and taken the diapragm assembly apart looking for a bad diaphragm and can not see any lite thru them. I have changed many of these over the years usually because they filled the crankcase but I can see a rupture. Is there a chance they are bad without being able to see it?
ram ranch
02-23-2007 21:00:48
 Re: 720 bowl diaphragms in reply to Mixman, 02-23-2007 16:15:15
but is there enough pressure to open the diaphram? or just fix it with some washers to make it stay open, by the time the oil pressure drop and the fuel ran out it was too late anyways
Kevin L
02-23-2007 18:40:30
if the diaphragms seem in good shape, I would wonder if the oil pressure line was clogged and hope that the engine has oil pressure since the oil pressure is what"s use to let fuel in to the bowl.
Mixman
02-23-2007 20:06:49
 Re: 720 bowl diaphragms in reply to Kevin L, 02-23-2007 18:40:30
(IT has good oil pressure to there!!!!! !!
Marv Scheb
02-25-2007 16:59:56
 Re: 720 bowl diaphragms in reply to Mixman, 02-23-2007 20:06:49
Hi Mixman, The automatic fuel shut off is the best thing John Deere put on the number series for fuel control. Don't ever block it open with washers unless you dont like the tractor and are going to waste it (the tractor I mean.) This diaphram operated unit will operate with as little as 5lbs of oil pressure. If you have 5lbs or less --- that tractor needs to come inside for some work. If you have it all apart then spend a few bucks put new diaphrams in it along with a new valve seal washer. Now before you slap it together clean all the parts make sure all mateing surfaces match good touching on the diaphram gasketting surfaces. Remove the oil lines and blow them out wash them blow them out some more.Keep in mind the line to the bowl assembly or return line could be nearly plugged reducing flow. Now before you screw this puppy in place just connect the oil lines and crank the engine while watching the valve inside of the bowl it only needs to turn over a few times and it will open if it dont open you need to do more trouble shooting. If you dont hyave oil flow amnd pressure, you definitely must find out what is wrong. By the way make sure you putt the castings together with the correct side up. Dont strip out the screws it only pot metal. Keep us posted Ray
