Gaskets for brakes on a John Deere A
craigreavley
02-23-2007 11:33:52
I am looking for the gaskets that go on the brake assembly next to the rear end. Mine have three bolts. The dealer says he has a gasket with two holes and one with four holes. Where do I get the three hole gaskets???I have a late styled A
G/MAN
02-23-2007 13:45:35
 Re: Gaskets for brakes on a John Deere A in reply to craigreavley, 02-23-2007 11:33:52
If the surfaces are clean and flat, you can do away with the gaskets entirely and just use an anaerobic form-in-place gasket maker. In fact, that stuff can be used in many areas of an old tractor with no problem whatsoever.
machinery-man
02-23-2007 13:43:34
you can get good quality material and use small ball pen hammer and make them....
t buzzard
02-23-2007 11:41:55
Get JD part number A3789R 3 holes for the cap screws one for the alignment pin.
The Dukester
02-23-2007 11:41:34
I believe the 4 holed gaskets oughta work, you should have an alignment dowel along with the three capscrews or studs and nuts
ram ranch
02-23-2007 11:39:21
those gaskets will work the other hole is for a line up pin or dowl pin
