want to go wide on 4020
5020s rock
02-23-2007 11:31:36
hello fellow tractor dudes--
is it much of a job to replace a narrow front
with a wide front on a 4020? are there early,
late model--gas, diesel considerations to the
project? thanks
Glen in TX
02-23-2007 19:40:43
 Re: want to go wide on 4020 in reply to 5020s rock, 02-23-2007 11:31:36
If wanted for HD loader duty they say some front end off a Case works well or the ones off some later JDs by adapting them.
ram ranch
02-23-2007 11:36:44
no really not that hard, just looseing four bolts on the narrow front pedastol,remove than four bolts to atach the wide front and bolts for your steering arms
Gerald J.
02-23-2007 12:27:17
 Re: want to go wide on 4020 in reply to ram ranch, 02-23-2007 11:36:44
After you convince someone to sell you the wide front which takes $1300 to 1500 crossing their palm, but salvage yards do sell the wide fronts for just that purpose.
Its also possible to mount heavier wide fronts from later series and other makes (including Schwartz which may be the opposite of heavier) which can take some adapters that are around.
Gerald J.
