1949 Deere M Final Drive Oil?
sschevrolet65
02-22-2007 16:06:48
Hello-
I am in the process of changing all the fluids on my M that I recently acquired. I have a shop manual on the way, but in the meantime, what oil do the final drives require? I replaced the gearbox oil with 85-140 after flushing the case with diesel. Can I use the same for the finals? Should I also flush them with diesel? (The gearbox is now full of new oil, if I add diesel to clean the finals will it effect the gearbox)? Also, does anyone know the capacity of oil the finals will take?
Thanks,
Matt
NJ
shrike
02-28-2007 04:44:50
 Re: 1949 Deere M Final Drive Oil? in reply to sschevrolet65, 02-22-2007 16:06:48
the 85-140 will work fine. and you dont need to worry about mixing fluids between the trans and the finals. theres a dry cavity beteen them that contains the disc brakes. take care not to spray oil or solvents in the hole where the brake control rod enters the final drive casting. the disc brake assembly is right above the hole against the output bearing quill on the trans. just a lil oil or solvent on the disc and the brakes won,t work!
jd51mt
02-22-2007 16:53:58
It holds 3 1/2 pints in each final. The manual calls for SAE 90. You should be able to flush the finals with out it getting into the gear box.
MIke
sschevrolet65
02-24-2007 07:10:31
 Re: 1949 Deere M Final Drive Oil? in reply to jd51mt, 02-22-2007 16:53:58
Hi Mike-
Thanks for your reply. I appreciate your time.
I guess I'll run the same 85-140 in the finals as that is what is in the rest of the tractor now.
Thanks again,
Matt
