Electrolsis FIT
Diesel man
02-22-2007 13:58:43
hey the web site helps alot but one minor detail we needed or at least this dumb kid needed was that the electorde shold be whole not be hollow... but it does work greta once i found the right soda.... when should i change the water??? thanks
gurneejoe
02-23-2007 05:24:04
 Re: Electrolsis FIT in reply to Diesel man, 02-22-2007 13:58:43
Do the chemicals deplete? Should more soda or lye be added from time to time or just leave it alone?
F-I-T
02-23-2007 06:24:01
 Re: Electrolsis FIT in reply to gurneejoe, 02-23-2007 05:24:04
No, they act as salts, and none is consumed in the process. If I have to thin the mix because I am cleaning a large part one day and small ones that the electrode can't get close to the next, I add water one day and add some washing soda the next. The concentration is not critical at all and you'll soon get the feel for if you should add "salt" or thin the mix.
F-I-T
02-22-2007 16:39:13
third party image
>>>.... when should i change the water??? >>>
Here is a picture of my tank a few years ago when I submitted to the guys in the "Ugliest Electrolysis Tank Contest". It won 1st prize. It was working perfectly, and I don't clean them until I have to move 'em. I just strain the junk off the surface with a minnow net. I get a faid amount of dead frogs in it during the rainy season as they jump and fall in.
>>>>but one minor detail we needed or at least this dumb kid needed was that the electorde shold be whole not be hollow...>>>>
Not sure what you mean here. My rule of thumb is that electrode works as a function of surface area, so you should have at least as much surface area for the electrode as you have surface of the parts being cleaned. The smaller of the two will determine the throughput of the cell. I like flat sheet that I can tack together and line the sides of the tank. I don't like it on the bottom where the flakes can fall down and cause a short either.
Frank
Frank
