4430,4440,or 4450?
jdgreen1
02-22-2007 01:11:32
Hey,my neighbor is interested in one of these three..he has found one of each..all three are Quad,cab,and 2-wd..the 4430 has 6300 actual hours and overhauled at 5900 hours..the 4440 has 6700 hours..no major work done..and the 4450 has 6800 hours with no major work done..all three are very nice..with the 4450 probably the nicest overall..asking price is 15,500 for the 30...22,000 for the 40...and 27,000 for the 50..'77,'81,and '86 model years..any advice or input for him would be greatly appreciated. Thanks in advance.
G/MAN
02-22-2007 07:38:54
 Re: 4430,4440,or 4450? in reply to jdgreen1, 02-22-2007 01:11:32
If the 4450 is nicer with similar hours to the 4440 for only $5000 more, I'd say it's a no-brainer. The 4450 has a much nicer cab, the 466 in that tractor will definitely be the later version with the crank-driven oil pump - no worries about a possible failure of the camshaft-driven oil pump gears. Only if it's a late 4440 will it have the crank-driven pump. The 4450 will also have better SCV boxes with standard ISO couplers - the 4440 and 4430 boxes have to be converted or adapters have to be used to plug in Pioneer tips. The 4450 also has a better lighting package, better HVAC system and the list goes on and on. He'll also want to keep in mind that both the 4430 and 4440 have mechanically-driven tachometers, and that the actual hours on the tractor are probably quite a bit higher than what's shown. Those tachs only put on hours accurately at rated engine speed - 2200 rpm. If the tractor is running 1000 rpm on an auger or something, you're putting on less than a half-hour for every hour the engine is actually running. The tach on the 4850 is electric and puts on true hours regardless of engine speed.
jdgreen1
02-22-2007 12:10:31
 Re: 4430,4440,or 4450? in reply to G/MAN, 02-22-2007 07:38:54
My neighbor wanted me to add that he'll be mainly using this tractor for tillage work and baling hay.
856 puller
02-23-2007 05:14:10
 Re: 4430,4440,or 4450? in reply to jdgreen1, 02-22-2007 12:10:31
the 4440 we had got worked on a lot. maybe it was problems from a previous owner or the 22" rows. axle and trans things mostly. i know of others that have had 10k hrs plus with no major work but like anything mechanical you can and will eventually have to fix. we have a 4450 and it has been good 8000ish hrs no major work i did lots of baling with a jd 100 and it rocked the tractor pretty good. we pulled a 16r planter and 30' drill with it and traction was a problem so we went to a 8100mfwd
G/MAN
02-22-2007 13:44:33
If lots of seat time is in the future, I'd go with the 50-series in a heartbeat. Capability-wise it won't be head and shoulders above the 4440, but comfort-wise and feature-wise, it will be a much friendlier tractor for long days in the field. And I wouldn't even consider the 4430 in this comparison. Darn good tractor and state of the art when new, but the 4440 was a huge jump over the 30-seris in comfort, capability and reliability, and the 50-series yet another big step.
JMS/MN
02-22-2007 07:34:31
Price on the 30 is a little high, until you factor in the overhaul, others are normal for here. Technology changes with each- bigger fuel tanks, better seating, other updates. My 4430 has 10800 hrs, only internal engine work was underhaul at 8700. 4450 MFWD has 9200 hrs, only engine work was injector pump. Both are Power Shift, no repairs. Sounds like three good ones to pick from.
J Schwiebert
02-22-2007 07:11:42
My son and his farming pardner have a 4430 and a 4440. I will probably be the only one that tells you this. They use the 4430 more than the 4440. The 4430 has 50% more hours than the 4440. They are equipped like you mention. Around here Power shift tractors are quite scarce. Can you get an oil analysis of each one run before you make a decision? How well has the coolant been maintained?
Minn.Norske
02-22-2007 05:25:03
The fellow that rents my farm has a 4430 with 17,000 hrs except for a camshaft replace it hasn't been touched. It's been used hard by a lot of operators. On the downside it's very cold blooded
Tx Jim
02-22-2007 03:37:37
I'd choose the 4440 or 4450 for easier cold weather starting and less fuel comsumtion. Both according to my dealer would require an underhaul and new hormonic balancer if not already done. I have a 4255 that that has given very good service. Tx Jim
