HELP! need advise on painting and decals- 830 ES
LWS
02-21-2007 18:12:37
Thanks! for all the help with fuel in oil problem, I am getting the 830 ready to paint and I would like you-all's opinion of decals. Should I paint the hood and sides green and apply full yellow decals, or paint yellow and apply the mylar? . I personally think that the full yellow decals would be better, are they hard or difficult to apply properly? Where should I get them? Any help would be appreciated Thanks! LWS
MLD
02-22-2007 06:02:04
 Re: HELP! need advise on painting and decals- 830 in reply to LWS, 02-21-2007 18:12:37
You can't get a full yellow decal. Paint the yellow & green & get a set vinyl decals. They are way more expensive than the mylar but look alot nicer. No film between the letters & no shiny, glassy look either.
F-I-T
02-21-2007 21:36:31
It's a personal decision, but I normally paint the small yellow portion first so that I can mask over it after it dries for a day or so, then paint the green. I'm just always afraid that I'll risk some yellow overspray on an entire tractor, or at a minuimum, the hood, if I spray the yellow last. It's a much smaller area to mask compared to masking the entire green tractor.
Either way, it's easier to get a nice job with the yellow paint than to apply the two, one piece table cloth sized yellow decals they used when new.
Frank
Mike M
02-21-2007 20:41:55
Paint the hood green then mask off and paint the yellow. This is how I was taught and it has worked well. And by all means get the die cut vynil decals as they won't show fingerprints like the ones with the clear backing between them.
ran ranch
02-21-2007 18:28:09
i don t think you can get full yellow decals, i would paint yellow first than green, than apply decals
dsofds
02-21-2007 18:24:06
that's the thing...they don't make "full yellow decals" like they did back when they built the tractor. You'll just have to paint it yellow then apply the decals.
