720D Pony Motor
Oliver Colterya
02-21-2007 14:48:49
The starter motor on the pony is needing to be rebuilt (ie, doesn't work~!). Anybody have some tips on the R & R of the starter? Any suggestions or things to avoid, etc, would be appreciated.
Thanks to all for past, present, and future help.
F-I-T
02-21-2007 15:00:44
 Re: 720D Pony Motor in reply to Oliver Colteryahn, 02-21-2007 14:48:49
Oliver:
It's a pretty straight forward 6v Delco unit. any starter shop will be able to freshen it up. They always need a nose bushing and generally a brush end bushing. and there's the brushes and tuen the commutator turning. That's about it unless you have armature/field troubles. You can do any of the work yourself with no problem.
Frank
Oliver Colteryahn
02-21-2007 20:26:32
 Re: 720D Pony Motor in reply to F-I-T, 02-21-2007 15:00:44
Thanks for the info on this. I do have a local rebuilder for the generators and starters. Any pitfalls or advice on removing the starter from the pony?
F-I-T
02-21-2007 21:30:57
 Re: 720D Pony Motor in reply to Oliver Colteryahn, 02-21-2007 20:26:32
Nope. It's one of the easiest Deere starters to remove. On my 70 that uses a starter pedal, I sometimes put a wire hook to the linkage so that I can guide it through, but I don't believe you have that problem on a 720D. I would suggest cleaning or replacing the switch,solenoid (depending what yours uses) when you have it out. What was/is the indicated problem with the starter?
Frank
Oliver Colteryahn
02-21-2007 22:21:27
 Re: 720D Pony Motor in reply to F-I-T, 02-21-2007 21:30:57
The issue is solenoid contact is made but starter does not turn. The motor does lack the cover band over the brushes (the one that wraps around the exterior). May occaisionally spin though. Do these use a bendix style engagement? Thanks.
Chuck730DSE
02-22-2007 11:16:53
 Re: 720D Pony Motor in reply to Oliver Colteryahn, 02-21-2007 22:21:27
As Frank states, the starter for the 720D pony is centrifugal force engagement.
While you have it down, clean the mating surfaces real good between the starter and casting that it bolts up to. This will ensure that you have a good electrical connection. Should just be two long bolts that hold the starter in place. As I recall, this is a good time to replace those pesky spark plugs on the back of the pony if they need it. Of coarse, replace them all at the same time but the front ones are easy to reach. With the starter out, you can "almost" get to them.
F-I-T
02-22-2007 10:49:30
The parts book calls it a "Motor Drive", and the 70D book calls it a "Bendix". Either is an overrunning type that engages by the motor turning, and not by the solenoid pulling or pushing a linkiage to engage.
Oliver Colteryahn
02-22-2007 14:43:47
 Re: 720D Pony Motor in reply to F-I-T, 02-22-2007 10:49:30
Thanks Chuck and Frankl. I had planned on cleaning the bolts/mounting surface to ensure good electrical contact. The tip on the spark plugs is great to know. I'll stop at the local Napa store and pick some up..... ....if they have them!! Thanks again.
F-I-T
02-22-2007 16:25:27
 Re: 720D Pony Motor in reply to Oliver Colteryahn, 02-22-2007 14:43:47
They should. I use Champion J8C's, and they cross to about every Briggs and Stratton lawn mower engine ever made. Don't use any long-bodied plus, and no resistors! I tried some NGK's, but they fouled pretty fast even in my rebuilt pony with new rings/valves/etc.
Oliver Colteryahn
02-23-2007 06:07:07
 Re: 720D Pony Motor in reply to F-I-T, 02-22-2007 16:25:27
Frank, thanks for the spark plug number, I stopped into the local JD dealer yesterday to check on what to use, and the parts guy couldn't find the pony motor in the system under 720/730 Diesel tractors!!! I do appreciater your time and tips you have passed along. They will long be remembered.
